show l2pt
show l2pt
Description
Displays the global parameters for L2PT.
Syntax Description
l2pt Displays global Layer 2 protocol tunneling parameters.
Default
Disabled.
Usage Guidelines
Use this command to display the global parameters for L2PT.
The following is an example of the command's output:
# show l2pt
Encapsulation Destination MAC Address: 01:00:00:01:01:02
This command was first available in ExtremeXOS 15.5.
Platform Availability
